[Debian Installer] timeline update and rc3 test images ready
debian 開發版,這個版面主要是要討論 debian@taiwan or debian@chinese 相關開發議題,所謂開發如 debian 中文化問題、文件製作維護問題、程式開發問題...最終目的是能從這個版面的討論成立一個接一個的工作小組來幫助 debian@taiwan or debian@chinese 發展,讓 taiwan 或華人能更方便的使用 debian。
文章Tetralet » 週一 3月 14, 2005 3:16 pm
Debian Installer 的 RC3 已準備好要推出了。
請參考:
The 20050305 build of debian-installer went well and is now available in the
debian archive[1]. We also have netinst and businesscard CD images using that
build, that seem to be good[2]. All the kernels are in the archive at last,
and I know of no other blocking issues that remain. So this is the beginning
of a testing period to make sure all the images really work well before we
release rc3. A week of testing will probably be time well spent, which gives
us the following timeline for the release:
10 Mar  debian-installer test build finishes (approximate)
        test period
17 Mar  final deadline for emergency changes for rc3 (optional)
        begin final debian-installer package build (optional)
19 Mar  final debian-installer package build complete (optional) [3]
20 Mar  final netinst and businesscard CD builds
        begin full CD builds
21 Mar  final testing
22 Mar  web site updates
23 Mar  rc3 release
I hope that we can test the new images and fill in a large percentage of the
release checklist[4]. The more that's filled in the more confidence we can
have that rc3 will not have any bad new problems. I'm also updating the
errata on the web site for rc3 as more minor problems are discovered.
Also, we need to get a release announcement put together for rc3. Perhaps we
should just say it fixes a lot of rc2 errata, security holes, and other bugs
and leave it at that?
see shy jo
[1] ftp://ftp.debian.org/debian/dists/sid/main/installer-i386/20050305/images/
[2] http://cdimage.debian.org/pub/cdimage-testing/daily/i386/20050309/
    (and other arches of course)
[3] I expect we can build it faster than before if we need to thanks to some
    improved prioritisation on the autobuilders.
[4] installer/doc/devel/release-checklist in the sarge branch of svn
因為這個版本將成為 Sarge 的安裝程式,
所以在使用上若遇到任何問題,
(尤其是中文方面的)
請不吝提出,謝謝!
時間並不能治療我心中的疼痛
南方的春天說什麼也溫暖不了我冰冷的血
誦唱大復活咒文,今天的 Tetralet 又在唧唧喳喳了 重生!
Tetralet
俺是博士
俺是博士
文章: 3078
註冊時間: 週四 11月 28, 2002 3:02 pm
文章caosheng » 週一 3月 14, 2005 3:23 pm
前面說的kernel 2.6 裝到base-config 會停住的問題解決了嗎
caosheng
文章: 222
註冊時間: 週一 12月 27, 2004 2:27 pm
文章Tetralet » 週二 3月 15, 2005 4:41 pm
caosheng 寫:前面說的kernel 2.6 裝到base-config 會停住的問題解決了嗎
不清楚。
可能要請原始貼文者測試回報了...
另,在 RC3 中好像發現了什麼重大瑕疵,
似乎(暫時)下架了...
時間並不能治療我心中的疼痛
南方的春天說什麼也溫暖不了我冰冷的血
Tetralet
俺是博士
俺是博士
文章: 3078
文章Tetralet » 週五 3月 25, 2005 12:43 am
Debian-Installer release candidate 3 已正式推出,
請參考新聞連結
真是令人興奮!
時間並不能治療我心中的疼痛
南方的春天說什麼也溫暖不了我冰冷的血
Tetralet
俺是博士
俺是博士
文章: 3078
文章caleb » 週五 3月 25, 2005 8:05 pm
昨天用 qemu 試用 rc3 網路安裝, 快完成時說找不到 kernel-image-2.6.8-2-386
換了三個 sources 都一樣, 蠻怪的...
看官方套件庫明明就還在...
caleb
文章: 15
註冊時間: 週一 3月 21, 2005 4:46 pm
文章Tetralet » 週三 3月 30, 2005 4:32 pm
caleb 寫:昨天用 qemu 試用 rc3 網路安裝, 快完成時說找不到 kernel-image-2.6.8-2-386
看官方套件庫明明就還在...
我也是用 QEMU 來安裝的,
安裝來源用的是 sarge-i386-netinst.iso,
沒有您所說的問題...
改天用 sarge-i386-businesscard.iso 來試試看...
時間並不能治療我心中的疼痛
南方的春天說什麼也溫暖不了我冰冷的血
Tetralet
俺是博士
俺是博士
文章: 3078
回到 debian develop
