架設wireless ap問題
這個版面主要討論 debian 在 server 端的應用問題, server 種類繁多..舉凡 Web Server 、 File Server、 DHCP Server..等等。
版主: 阿信
架設wireless ap問題
文章THQ » 週三 7月 20, 2011 10:18 am
kernel:2.6.39-2-486
driver: rt2800pci
無線網卡:EW-7711In(ralink 3060 chip)
hostapd.conf:
ssid=hihi
hw_mode=g
channel=1
interface=wlan0
driver=nl80211
wpa=2
wpa_passphrase=123456abc
wpa_key_mgmt=WPA-PSK
hostapd執行時沒有錯誤訊息,但是用ipad2搜尋wifi就是找不到,
有什麼方法可以檢測目前無線ap是否正常呢?
如果用官方的driver,是可以開啟ad-hoc模式,ipad2也搜尋的到
Linux才是最強的!!
THQ
文章: 492
註冊時間: 週二 1月 04, 2005 9:11 pm
Re: 架設wireless ap問題
文章THQ » 週六 7月 23, 2011 12:14 pm
hostaqpd啟動訊息
Configuration file: tt.conf
nl80211: Add own interface ifindex 3
nl80211: New interface mon.wlan0 created: ifindex=15
nl80211: Add own interface ifindex 15
BSS count 1, BSSID mask 00:00:00:00:00:00 (0 bits)
nl80211: Added 802.11b mode based on 802.11g information
Allowed channel: mode=1 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=1 chan=11 freq=2462 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=1 freq=2412 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=2 freq=2417 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=3 freq=2422 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=4 freq=2427 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=5 freq=2432 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=6 freq=2437 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=7 freq=2442 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=8 freq=2447 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=9 freq=2452 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=10 freq=2457 MHz max_tx_power=20 dBm
Allowed channel: mode=0 chan=11 freq=2462 MHz max_tx_power=20 dBm
RATE[0] rate=10 flags=0x1
RATE[1] rate=20 flags=0x1
RATE[2] rate=55 flags=0x0
RATE[3] rate=110 flags=0x0
Completing interface initialization
Mode: IEEE 802.11b Channel: 1 Frequency: 2412 MHz
Flushing old station entries
Deauthenticate all stations
wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=(nil) key_idx=0 set_tx=1 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=3 alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
Using interface wlan0 with hwaddr 00:1f:1f:d8:ad:8c and ssid 'zootest'
nl80211: Set beacon (beacon_set=0)
wlan0: Setup of interface done.
RTM_NEWLINK: operstate=0 ifi_flags=0x1002 ()
RTM_NEWLINK, IFLA_IFNAME: Interface 'mon.wlan0' added
Unknown event 5
RTM_NEWLINK: operstate=0 ifi_flags=0x11043 ([UP][RUNNING][LOWER_UP])
Unknown event 5
RTM_NEWLINK, IFLA_IFNAME: Interface 'wlan0' added
Unknown event 5
Signal 2 received - terminating
nl80211: Remove interface ifindex=15
netlink: Operstate: linkmode=0, operstate=6
Linux才是最強的!!
THQ
文章: 492
回到 debian server
