[問題] Network Manager在Debian上編譯
debian 開發版,這個版面主要是要討論 debian@taiwan or debian@chinese 相關開發議題,所謂開發如 debian 中文化問題、文件製作維護問題、程式開發問題...最終目的是能從這個版面的討論成立一個接一個的工作小組來幫助 debian@taiwan or debian@chinese 發展,讓 taiwan 或華人能更方便的使用 debian。
文章huki » 週四 10月 13, 2005 12:03 pm
今天看到Jack大大的blog
看到這一篇http://chuany.net/?p=86
覺得這個applet相當的不錯
圖檔
不過本人目前是沒有辦法編成功
因為實在太多錯誤了
小弟先去官網下載原始碼
解開後
先configure一下
[root@nb-huki ~/NetworkManager-0.4]# ./configure
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking whether gcc and cc understand -c and -o together... yes
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking for a sed that does not truncate output... /bin/sed
checking for egrep... grep -E
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for /usr/bin/ld option to reload object files... -r
checking for BSD-compatible nm... /usr/bin/nm -B
checking whether ln -s works... yes
checking how to recognise dependent libraries... pass_all
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking dlfcn.h usability... yes
checking dlfcn.h presence... yes
checking for dlfcn.h... yes
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking dependency style of g++... gcc3
checking how to run the C++ preprocessor... g++ -E
checking for g77... no
checking for f77... no
checking for xlf... no
checking for frt... no
checking for pgf77... no
checking for fort77... no
checking for fl32... no
checking for af77... no
checking for f90... no
checking for xlf90... no
checking for pgf90... no
checking for epcf90... no
checking for f95... no
checking for fort... no
checking for xlf95... no
checking for ifc... no
checking for efc... no
checking for pgf95... no
checking for lf95... no
checking for gfortran... no
checking whether we are using the GNU Fortran 77 compiler... no
checking whether  accepts -g... no
checking the maximum length of command line arguments... 32768
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for objdir... .libs
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking if gcc static flag  works... yes
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC
checking if gcc PIC flag -fPIC works... yes
checking if gcc supports -c -o file.o... yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
configure: creating libtool
appending configuration tag "CXX" to libtool
checking for ld used by g++... /usr/bin/ld
checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes
checking for g++ option to produce PIC... -fPIC
checking if g++ PIC flag -fPIC works... yes
checking if g++ supports -c -o file.o... yes
appending configuration tag "F77" to libtool
checking for ANSI C header files... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking paths.h usability... yes
checking paths.h presence... yes
checking for paths.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/time.h usability... yes
checking sys/time.h presence... yes
checking for sys/time.h... yes
checking syslog.h usability... yes
checking syslog.h presence... yes
checking for syslog.h... yes
checking for unistd.h... (cached) yes
checking for mode_t... yes
checking for pid_t... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether gcc needs -traditional... no
checking for working memcmp... yes
checking for select... yes
checking for socket... yes
checking for uname... yes
checking locale.h usability... yes
checking locale.h presence... yes
checking for locale.h... yes
checking for LC_MESSAGES... yes
checking libintl.h usability... yes
checking libintl.h presence... yes
checking for libintl.h... yes
checking for ngettext in libc... yes
checking for dgettext in libc... yes
checking for bind_textdomain_codeset... yes
checking for msgfmt... /usr/bin/msgfmt
checking for dcgettext... yes
checking for gmsgfmt... /usr/bin/msgfmt
checking for xgettext... /usr/bin/xgettext
checking for catalogs to be installed...  bs cs da de el en_CA es fr gu hr hu it ja nb ne nl no pa pt_BR rw sk sq sv uk wa zh_CN zh_TW
checking for /etc/mandrake-release... no
checking for /etc/redhat-release... no
checking for /etc/fedora-release... no
checking for /etc/gentoo-release... no
checking for /etc/debian_version... yes
checking for /etc/slackware-version... no
checking iwlib.h usability... no
checking iwlib.h presence... no
checking for iwlib.h... no
configure: error: iwlib.h not found. Install wireless-tools.
本來以為是沒裝wireless-tools的關係
可是我的ipw2100己經可以使用了
所以我之前也裝了wireless-tools了
若有大大會的請麻煩幫小弟debug一下
麻煩了~~~謝謝
Linux給我的感覺就是自由自在,沒有壓力
希望大家都能參與linux
變成linux世界的一份子
HuKi
huki
快樂的大學生
快樂的大學生
文章: 783
註冊時間: 週四 11月 28, 2002 7:27 am
來自: 家:中壢/公:桃園
文章訪客 » 週四 10月 13, 2005 12:29 pm
缺 iwlib.h
請安裝 libiw-dev
用 apt-file 可以尋找你欠的檔案
文章huki » 週四 10月 13, 2005 1:04 pm
缺太多了
快瘋了~~~
算了吧!
看有沒有大大能編一下
果然對我還是有點難度
我只能用非正統的
大概缺了
libiw-dev dbus-glib-1-dev libhal-dev libgtk2.0-dev libglade2-dev libgconf2-dev libgnome-keyring-dev
不過目前卡在相依libpanelappletmm-2.6-1的問題
有空再來吧!><"
希望大家都能參與linux
變成linux世界的一份子
HuKi
huki
快樂的大學生
快樂的大學生
文章: 783
來自: 家:中壢/公:桃園
文章wsun013 » 週五 10月 14, 2005 11:10 pm
要自己編的話, 這些 lib*-dev 是不可免的
huki 大大只能裝下去了
小弟的debian 就肥在這個地方
------BEGIN GEEK CODE BLOCK------
Version: 3.12
GE d->++ s: a-- C+++>++++ UL>++++ P>++++ L++>++++ E---- W+ N@ o K- w++(+)
O- M- V? PS+++(+) PE++(+) Y-- PGP- t>--- 5? X+++ R- tv-(--) b+ DI? D+ G e++>++++
h+(!) r++(%) y*>++++
-------END GEEK CODE BLOCK-------
wsun013
快樂的大學生
快樂的大學生
文章: 784
註冊時間: 週二 9月 14, 2004 12:12 pm
來自: 紐西蘭
回到 debian develop
